Can any one help me out why i was not able to avoid .aspx extension for ssl web sites working fine with the non ssl web sites
SSL shouldnt make any difference. Have you set the <add key="umbracoUseDirectoryUrls" value="true" /> value in the web config?The rest of the changes are IIS based.
The change is already in place and working fine with non-ssl sites on the same installation.
unable to avoid .aspx extension for ssl enabled web sites
