  • Simon 81 posts 184 karma points
    Sep 06, 2011 @ 17:35
    Simon
    Advice about carousels
    Afternoon all,
    I'm a relative newbie to Umbraco although I seem to be getting on with it reasonably well.
    I'd like some advice on the best way to implement a carousel, in particular how best to capture the following details for an unknown number of slides.
    • caption
    • url (from content picker)
    • image (from media picker)
    I'm quite happy generating the HTML for carousel itself - it's the method for capturing the information I'm interested in. I could add a tab to the document type with "slide 1 caption", "slide 1 Url", "slide 1 image" etc. but I don't want to restrict the number of images. Equally I've seen forum posts about creating a mini document type to hold the information. Then add as many of these as required as the children of the main content page and use XSLT to loop through them.
    Any ideas on "best practice" or how other people do it would be much appreciated.
    Cheers
    Simon
    Sep 06, 2011 @ 20:37
    Dirk De Grave
    May have a look into this project, could be exactly what you need.
    As for your question, ... 2nd method is preferred as it's more extensible... Above project does use a slightly different approach...
    /Dirk,
  • Mike Chambers 636 posts 1253 karma points c-trib
    Sep 07, 2011 @ 10:40
    Mike Chambers
    we use a custom mediaType with additional parameters (you would have your caption etc...), as we don't really want the media items as documnets in the hierarchy.
    then the xslt draws all the added custom media types in a specific media folder using a media picker either in the macro or as a doc type parameter...
    the xlst important bit is...
    {!--macro param--}
    xsl:variable name="MediaNodeId" select="/macro/MediaNode/Folder/@id"/>
    or
    {!--doc param--}
    <xsl:variable name="MediaNodeId" select="$currentPage/MediaNode/Folder/@id"/>
    <xsl:for-each select="umbraco.library:GetMedia($MediaNodeId, 1)/{CUSTOMMEDIATYPE}">
    </xsl:for-each>
    Sep 21, 2011 @ 15:22
    Simon
    Thanks for the replies guys - went with a custom media type in the end with Url, image, caption etc.
    Cheers
    Simon
