  • Fredrik Esseen 610 posts 906 karma points
    Sep 07, 2011 @ 09:25
    Fredrik Esseen
    Row numbers in css not displaying in 4.7
    Hi!
    Ive made my first installation on 4.7 and noticed that the row numbers in css has disappeared?
    Is it just my installation?
    Can i check some config file for whats missing?
  • Mike Chambers 636 posts 1253 karma points c-trib
    Sep 07, 2011 @ 10:34
    Mike Chambers
    Is it just that you are viewing in IE?
    "NOTE! Even though CodeMirror is enabled by configuration, it is disabled in Internet Explorer because it's not stable enough."
    I've just checked 4.5.2 and 4.7 and in IE neither show the line numbers, presumably as no CodeMirror.... in FF6 the line numbers are there :-)
    Sep 07, 2011 @ 10:46
    Fredrik Esseen
    Nope. using FF latest version.
