  • Stephen 204 posts 246 karma points
    Sep 12, 2011 @ 11:48
    Stephen
    Paypal Minicart
    I'm following this WIKI, which is exactly what i need...
    http://our.umbraco.org/wiki/how-tos/quick-paypal-minicart-store-with-umbraco
    but is the XML now out of date? cant seem to get my values for the paypal forms...
    S
    Sep 12, 2011 @ 12:50
    Rich Green
    Hey Stephen,
    You could try the automatic XSLT converter provided by Tommy here  http://blackpoint.dk/umbraco-workbench/tools/convert-xml-schema-to-45-.aspx
    Rich
    Sep 12, 2011 @ 13:01
    Stephen
    Thanks Rich, code is coming back as the same but i'm not getting any values, weird. This should be a lot easier than it is...
    S
    Sep 12, 2011 @ 13:05
    Rich Green
    The code shouldn't be the same at all so somethings wrong? For the schema changes see http://our.umbraco.org/wiki/reference/xslt/45-xml-schema/no-more-@nodetypealias
    You'll also need to change  umbraco.library:GetXmlNodeById(1053) to reflect your node id.
    Rich
    Sep 12, 2011 @ 13:12
    Stephen
    Hi Rich,
    Yeah i removed that line so i put in the Paypal email manually in the code..
     <input type="hidden" name="business" value="XXXXX@XXXXXcom"/>
    which is working..
    Looking at one of the lines of code it reads.. and I'm not sure what "data" refers to...never had to do this in any other XSLT?
    <inputtype="hidden"name="amount"value="{data
    [@alias = 'productPrice']}"
    Sep 12, 2011 @ 13:14
    Rich Green
    That looks like old XSLT, anything with @alias in it is old schema.
    Rich
    Sep 12, 2011 @ 13:30
    Stephen
    Managed to work it out with a bit of trial and error...xslt converter wasn't converting...
    <inputtype="hidden"name="amount"value="{data [@alias = 'productPrice']}"/>
    Becomes simply..
    <inputtype="hidden"name="amount"value="{productPrice}"/>
    Hope this helps somone out!
    S
