  • niccolo rossi 33 posts 53 karma points
    Sep 12, 2011 @ 12:02
    niccolo rossi
    for each return always the firts value
    Hi all,
    i've a macro with a variabile that contain 3 data row called "test" and a for each.
     <xsl:variable name="test"
      select="umbraco.library:GetXmlNodeById(1091)//umbNewsArticle
      [string(visibileInHomePage) = '1' and string(numeroPubblicazione) =$currentPage/numeroPubblicazione]" />
      <xsl:for-each select="$test  ">
    if i ask the node name of the data row all works fine but when i call a info contained in it
    <xsl:value-of select="$test/settore" />
    the macro display 3 time the first row value.
    how can i resolve this?
    there is a book where i can study this things?
    thank you
    nico
    Sep 12, 2011 @ 12:57
    Lee Kelleher
    Hi Nico,
    Try removing the $test from the 'select':
    <xsl:value-of select="settore" />
    Reason is that once you are inside the for-each loop, you already have the context of the $test variable, so don't need to reference it again.
    If you want to learn more about XSLT, you could try the W3Schools tutorials? http://www.w3schools.com/xsl/
    ... or if you are from more of a C# background, then take a look at Razor?
    Cheers, Lee.
