  • Jamie Wu 19 posts 79 karma points
    Sep 13, 2011 @ 17:30
    Jamie Wu
    Ultimate Picker and macro parameters
    Hi there,
    I am using a Ultimate Picker (Berto) to get a list of one node's children. It is a multisite installation. The nodes structure is showing below:
    - Content
    - - Template A
    - - - V1
    - - - - Site 1
    - - - - - Container
    - - - - - - Item 1
    - - - - - - Item 2
    - - - - Site 2
    As illustrated, The Template is a folder, then V1 is a sub-folder, Site 1 and Site 2 are under V1.
    The Ultimate Picker is a property of Site 1 and is able to get the list of 'Container' children as checkboxes. I am also using a Macro with a parameter from alias [#ultimatepicker] to get the nodeIDs of Item 1 and Item 2. However for some reasons, the macro parameter is unable to get actual IDs of Item 1 and Item 2.
    I am wondering if the [#] or [$] works like its going through the node from root of 1st level (Template A) rather the Current one (Site 1, Site 2).
    Hope I am expressing myself well.
    Jamie
  • Tom Hare 49 posts 81 karma points
    Sep 13, 2011 @ 17:38
    Tom Hare
    Hi Jamie,
    Are you using XSLT for this? Could you post the code so we can see?
    Tom
    Sep 13, 2011 @ 17:51
    Jamie Wu
    Thanks for the very quick reply Tom.
    I am not using XSLT on this solution. All is umbraco itself and .Net. In the Ultimate Picker (Berto) I set the 'Parent Filter' as the alias of the 'Container'. The macro is actually a user control. The macro itself is <umbraco:Macro Widgets="[#ultimatePicker]" Alias="SidebarWidgets" runat="server"></umbraco:Macro>
    There is bit of code of user control
    using System.Diagnostics;
    using umbraco.presentation.nodeFactory;
    using umbraco.presentation.templateControls;
    using uComponents.Core;
    using uComponents.Core.uQueryExtensions;
    using umbraco.BusinessLogic.Actions;
    namespace SidebarWidgets
        public partial class SidebarWidgets : System.Web.UI.UserControl
            private string widgets;
            public string Widgets
                get { return widgets; }
                set { widgets = value; }
            protected void Page_Load(object sender, EventArgs e)
                this.widgetRepeater.DataSource = uQuery.GetNodesByCsv(this.widgets);
                this.widgetRepeater.DataBind();
            /// <summary>
            /// for each widget set and add an Item control
            /// </summary>
            protected void WidgetRepeater_ItemDataBound(object sender, RepeaterItemEventArgs e)
                if (e.Item.ItemType == ListItemType.Item ||
                    e.Item.ItemType == ListItemType.AlternatingItem)
                    Node widgetNode = (Node)e.Item.DataItem;
                    PlaceHolder contentPlaceHolder = (PlaceHolder)e.Item.FindControl("ContentPlaceHolder");
                    Item item = new Item();
                    item.NodeId = widgetNode.Id.ToString();
                    item.Field = "content";
                    contentPlaceHolder.Controls.Add(item);
