  • Fuji Kusaka 2203 posts 4220 karma points
    Sep 15, 2011 @ 08:54
    Fuji Kusaka
    Archiving news items with a Boolean
    Hi all,
    I have a client of  mine who has a News section, upcoming and past news (archives). So what he wants is to have 2 seperate folders with the following structure
    News
    1. Upcomning
    2. Archives News
    Now the idea is to be able to move a Content Node from Upcomming News to Archives News by using a dropDown True/False which will allow the user to archive the news and at same this node will move to the Archives News folder.
    Anyone can point out how to achieve this instead of using the traditional move to folderin umbraco.
    //fuji
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    Sep 15, 2011 @ 09:03
    Hendy Racher
    Hi Fuji,
    How about an event handler that on save will check the property value and move it to the appropriate folder ?
    HTH,
    Hendy
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Sep 15, 2011 @ 09:08
    Richard Soeteman
    Hi Fuji,
    Checkout demo 2 of the event samples I wrote a while back.Almost what you need I think.
    Richard
    Sep 15, 2011 @ 09:18
    Fuji Kusaka
    @Hendy
    The Auto archive news  in Example 2 seems to be the right one. But thing is that the client do not have an expiry date for the Items.
    @Richard
    The link you sent is not working.Is it the link Hendy sent?
    //fuji
    Sep 15, 2011 @ 09:28
    Richard Soeteman
    Hi Fuji, yes the same link only to the wiki. sorry thought it only contained an overview. But you only need to change the date expire functionality to act on the value of the archived field on your document type and then it should work
    Sep 15, 2011 @ 11:13
    Fuji Kusaka
    Thanks Richard,
    I downloaded the zip file, is there any documentation to this?So i just need to change the way the date expire functionality will work, in my case change the alias and make sure when it returns to 1 the node will go under the Archieve news folder.
    //fuji
  • Jigs 40 posts 63 karma points
    Sep 20, 2011 @ 02:46
    Jigs
    Hi Fuji,
    I have working solution for AutoArchive, which can archive your node from upcoming to archive news .... if you want to use it just change the alias of docunment type and property alias in this class file also change the node id of your archive folder and original folder. it will give you functionality of auto move to archive and if you want to move back to original folder agian when you click the save button ......
    Here is the attached code :
     This solution is based on the example available on the Umbraco wiki... thankx to writer
    Jigs
    Sep 20, 2011 @ 05:30
    Fuji Kusaka
    Hi Jigs,
    Thanks for the help, I'll give this a try and will let you know, i also like Richards Method.
    Cheers
    //fuji
    Sep 20, 2011 @ 08:00
    Richard Soeteman
    Hi Fuji,
    The Example Jigs used does pretty much the same as my example. Sorry for the late reply, kinda snowed under.
    Richard
    Sep 20, 2011 @ 08:35
    Jigs
    Hi Richard,
    I think i used your example when i wrote this code ,,,, Thanks for such a good example but i got the problem when i pressed the save button using your example so ....it doesnt move the node to archive .... actualy i need to Click save button two times to move it to archive folder...... and then i twisted the code litl bit using doc instead of using sender directly ...and now its working well .... it move the node in single click .... but anyway great example and great help to other users by your example. Much appriciated.
    Jigs
    Sep 20, 2011 @ 11:41
    Fuji Kusaka
    Hi Jigs,
    I gave this a try but nothing is happening. Am not sure of doing the propert way thought. What i did i added your code in my template instead wrapped in a <script language ="C#">
    Sep 21, 2011 @ 02:18
    Jigs
    Hi Fuji,
    i will tell you the step by step what you need to do
    1. make a new visual Studio project --- give name
    2. add a new item --- class give a name AutoMoveToArchive
    3. now copy the code i gave you to the class file
    4. build the project
    5. copy the assembly to your umbraco bin folder
    6. and refresh the catch by touching the web.config
    7. now all done , go to archive folder and give it a try ...
    Jigs
    Sep 21, 2011 @ 07:40
    Fuji Kusaka
    Hi Jigs,
    Thanks for the reply again, i will work this out later. One question, how did you tell you node that this page is an Archive? Am using the a true/false select dropdown with a document alias archive. Are you using the same method?
    //fuji
    Sep 21, 2011 @ 07:54
    Jigs
    Hi Fuji,
    I used a --- property in my document type ---- boolean ---- when i designed it called ---- Archive ---- which is the check box type
    ok so when you click on Archive and click SAVE button it will move this node to Archive folder and again .... in archive folder if you unchecked it and click save button it will move back to original folder ....
    It works fine for me and I think pritty WELL
    Hope it will help you
    Jigs
    Sep 21, 2011 @ 08:00
    Fuji Kusaka
    Ok, so am doing the pretty much the same thing. I will let you know, but thanks for the help.
    Sep 21, 2011 @ 08:11
    Jigs
    ok no worry,
    If you find it as solution ...... give hive five .....
    Jigs
