  • Mattias 52 posts 75 karma points
    Sep 15, 2011 @ 14:48
    Mattias
    Extensionless url 4.7
    Im building a site in 4.7 (latest stable) .net 4.
    I tried to configure for extensionless url's and i dont get any errors but when i browse to a page. eg: /about.aspx i get the correct page, and /about/ gets me the first page in umbraco. All pages browsed to extensionless (eg. no .aspx) gets me the startpage. I get no errors but i only get the startpage.
    Running on IIS 7.
    Sep 15, 2011 @ 15:02
    Rich Green
    Did you republish your site after making the change in web.config?
    Rich
    Sep 15, 2011 @ 15:55
    Mattias
    I have republished entire site, published all nodes manually many times. Hacked web.config, restarted website in iis.
    No changes what so ever.
    Sep 15, 2011 @ 16:00
    Rich Green
    hmm.
    What did you do to configure the extensionless url's, should just be one change in the web.config file for 4.7 in II7.
    Rich
    Sep 15, 2011 @ 16:07
    Mattias
    Have just set the "umbracoUseDirectoryUrls" to true, and then by some searching i set the rewrite module's preCondition to "".
    But neither has done anything, i have directory urls set to false now but can still browse without .aspx without errors (maye should be so).
    Sep 15, 2011 @ 16:11
    Rich Green
    I'm pretty sure you shouldn't have to touch any rewrite conditions at all or IIS, unless something changed from 7 to 7.5
    What mode is your Application Pool set to?
    Rich
    Sep 15, 2011 @ 16:23
    Mattias
    I'm running the pool on .net 4 and integreated pipeline. Had the same problem before setting the preCondition too.
    Sep 15, 2011 @ 16:29
    Rich Green
    Hey.
    I'm out of ideas, what OS is the site running on?
    Rich
    Sep 16, 2011 @ 08:58
    Mattias
    Im running a Windows 7.
    Im not getting any errors just that the page is always the startpage if directory urls is used.
    Sep 16, 2011 @ 09:02
    Rich Green
    Hey,
    Sorry to hear you're having trouble.
    Prehaps it's time for a fresh Umbraco install.
    I run Windows 7 and all if I
    install Umbraco from Web Platform installer,
    install a starter kit,
    set umbracoUseDirectoryUrls to true
    There's *nothing* else I have to do to get it working, which means either there's something strange with the site you're working on, or there's something up with your IIS settings.
    Either way a clean Umbraco install might give you some more insight?
    Rich
