  • Traka 2 posts 22 karma points
    Sep 21, 2011 @ 06:59
    Traka
    'Sort' function within CMS
    Hi all,
    I'm trying to use the 'Sort' function within the CMS to re-order the way articles are listed on a site but it only seems to take effect in the backend and not the frontend. Is the 'Sort' function used for backend purposes only?
    Would be grateful for any advice/tips.
    Sep 21, 2011 @ 08:03
    Rich Green
    Hey Traka,
    Welcome to the forum!
    The sort function in the back end will sort the way the nodes are displayed and also how they are held in the xml file ready to be used on the front end.
    How you display them is up to you, if you are using XSLT and not doing any specific sorting then yes, the sorting should follow the back end.
    Rich
    Sep 21, 2011 @ 08:22
    Traka
    Thanks Rich!
    Appreciate it.
