Hi all,
the site is ready, now i've to install it, i just need a hosting provider with support for Aspx and Sql server.
Right?thank you
Yes right, transfer it all (Files and DB) update the webconfig to point to new SQL instance and your away at the races! I would recommend a cloud or virtual server.
Stephen
Upload image
Site ready! and now? hosting question
Hi all,
Right?
thank you
Stephen
