Everytime i use HTML input in TinyMCE and insert for example or a brake <br /> it is removed after saving. How can i stop removing this brakes and spaces?
Have a look at tinyMceConfig.config and the validElements section. You'll need to restart the app pool after any chnages or 'touch' the web.config (does the same thing).
By default, umbraco throws the content of the tinyMCE through tidy to cleanup possible bad html. It does that according to the validelements as described above. And basically it is to prevent editors to break the valid html.
In your case, you can do 2 things:
1 disable the tidyeditor completely (set TidyEditorContent in umbracosettings to false)
2 edit the tinymceconfig-file to allow empty spaces on all elements you want (every element is listed in the tinymceconfig-file, so to allow <p> </p> change -p to #p etc)
TinyMCE removes brakes and spaces
Hi Dominik,
Have you try to set the convertLineBreaks to false where you are add you umbraco:Item for your RTE
<umbraco:Item convertLineBreaks="true" runat="server" />Have a look at tinyMceConfig.config and the validElements section. You'll need to restart the app pool after any chnages or 'touch' the web.config (does the same thing).
HI Fuji,
The problem is that they are also removed from HTML block in TinyMCE
SO i insert for example and if i go back into the HTML view the is removed from code. So if I save it again it does not work any more.
So everytime i use HTML and save it - umbraco must save completly the HTML which i have set.
For example a blank table row "<tr><td> </td></tr>" is removed completly if i go back to HTML view.
But it should show exactly the same HTML as i inserted before
Dominik,
open up tinymceconfig.config and look for the validElements-section.
There's a setting -td[someallowedstuff]
Change that to #td
-td causes empty cells to be removed (see here: http://www.tinymce.com/wiki.php/Configuration:valid_elements)
Peter
Thanks Peter,
But this problem is not only occuring on <td> also if i insert a <p> </p> etc.
Is there a possibility to show exactly the same HTML code which has been inserted after saving?
Does this help?
Peter
HI Peter,
I set TidyEditorContent to false, touched web.config but still it removes after saving from html view
