  • Vincent 1 post 21 karma points
    Sep 27, 2011 @ 15:23
    Vincent
    Problem inserting macros into Richtext editor
    I have an issue inserting macros into the Richtext editor - in the Content section, when I click "Insert Macro" and then select the macro, it is placed above the tags for the page, rather than in the WYSIWYG editor. The macro then does not appear on the page at all when the page is saved and published. This is the case regardless of the macro, and regardless of the page/template used. The macros work when added to templates.
    I am using Umbraco 2.1, and Windows 7.
