We just upgraded our site from 4.5.0 to 4.7.1. The site works fine, but we can't get any of the nodes under or main content node in the backend.
I used firebug to figure out the script error and found the page that it's trying to hit and the error. Does anyone know how to fix this or what I might try?
Source Error:
Stack Trace:
umbraco.cms.businesslogic.web.Document.get_UserId() +22
umbraco.cms.presentation.Trees.BaseContentTree.GetUserActionsForNode(Document dd) +45
umbraco.cms.presentation.Trees.BaseContentTree.Render(XmlTree& Tree) +114
umbraco.loadContent.Render(XmlTree& tree) +19
umbraco.presentation.webservices.TreeDataService.LoadTree(TreeRequestParams treeParams) +75
umbraco.presentation.webservices.TreeDataService.GetXmlTree() +140
umbraco.presentation.webservices.TreeDataService.ProcessRequest(HttpContext context) +55
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +100
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
No nodes under main content after 4.7.1 upgrade
/umbraco/webservices/TreeDataService.ashx?rnd=b38e5181606c4e7a8833da8efcee55f3&id=1137&treeType=content&contextMenu=true&isDialog=false&rnd2=54.2%20500
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Fixed. Some of the nodes had a user that was deleted. I changed the userIDs on those nodes to the ones there were in umbraco and it worked.
Thanks, you just solved my problem :)
