  • Uros Sankovic 107 posts 134 karma points
    Sep 28, 2011 @ 08:14
    Uros Sankovic
    How to create different menus with submenus?
    Dear Umbraco users,
    Here's my story. I have usual web page structure
    HOME
    Page 1                  Page2                   Page3                   Page4                   Page5
    Subpage1           subpage1                                           subpage1            subpage1
    Subpage2           subpage2                                           subpage2            subpage2
    Subpage3
    Based on that I've created a menu with dropdown submenu.
    Subpage3
    So far everything is easy. Now, let say that after user clicks on Page4 or its submenu items, the menu changes to:
    Subpage1           Subpage2           Page 1                  Page2                   Page3                   Page5
    Subsubpage1    subsubpage1    subpage1            subpage1                                           subpage1
    Subsubpage2    subsubpage2    subpage2            subpage2                                           subpage2
    Subsubpage3                                   subpage3
    As you can see, there is no longer Page4, there are only its subpages, which moved into main menu level (subpages, written in BOLD). The same thing happens when the user clicks on Page 5. I've got it working with »NOT in the menu« - TRUE/FALSE, but it happend that I have four of those and it gets pretty confused. I'm using 5 macros for that: one for FULL main menu, one for the main menu, when there is no Page4, one for Page4 menu, one for when there is not Page5 and one for Page5 menu. And then I just put them in different templates. Is there any easier way to do that?
    Here's the code (XSLT) - full main menu:
    <?xml version="1.0" encoding="UTF-8"?>
    <!DOCTYPE xsl:stylesheet [
        <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
        <xsl:output method="xml" omit-xml-declaration="yes" />
        <xsl:param name="currentPage"/>
        <!-- Input the documenttype you want here -->
        <xsl:variable name="level" select="1"/>
        <xsl:template match="/">
        <!-- The fun starts here -->
        <xsl:for-each select="$currentPage/ancestor-or-self::* [@level = $level]/* [string(mainNavHide) != '1' and @isDoc]">
          <xsl:choose>
            <xsl:when test="@nodeName= 'Akcije'">
              <li>
                <class="curtainIt drop" href="{umbraco.library:NiceUrl(@id)}">
                  <xsl:value-of select="@nodeName"/>
                </a>
                <xsl:if test="(count(current()/* [string(mainNavHide) != '1' and  @isDoc]) > 0)">
                <div class="col_1 firstcolumn">
                 <ul class="levels">
                           <xsl:for-each select="current()/* [@isDoc]">
                      <li>
                     <href="{umbraco.library:NiceUrl(@id)}">
                               <xsl:value-of select="@nodeName"/></a>
                      </li>
                    </xsl:for-each>
                  </ul>
                </xsl:if>
              </li>
            </xsl:when>
            <xsl:otherwise>
              <li>
                <class="drop" href="{umbraco.library:NiceUrl(@id)}">
                </a>
                 <ul class="levels">
                      <li>
                      </li>
                    </xsl:for-each>
                  </ul>
                </xsl:if>
              </li>
            </xsl:otherwise>
          </xsl:choose>
        </xsl:for-each>
      </xsl:template>
     </xsl:stylesheet>
    Main menu without Page4:
    <xsl:stylesheet
      version="1.0"
        <xsl:for-each select="$currentPage/ancestor-or-self::* [@level = $level]/* [string(Page4NavHide) != '1' and @isDoc]">
          <xsl:choose>
              <li>
                <class="curtainIt" href="{umbraco.library:NiceUrl(@id)}">
                </a>
                <xsl:if test="(count(current()/* [string(Page4NavHide) != '1' and  @isDoc]) > 0)">
                 <ul>
                      <li>
                      </li>
                    </xsl:for-each>
                  </ul>
                </xsl:if>
              </li>
            </xsl:when>
            <xsl:otherwise>
              <li>
                </a>
                 <ul>
                      <li>
                      </li>
                    </xsl:for-each>
                  </ul>
                </xsl:if>
              </li>
            </xsl:otherwise>
          </xsl:choose>
        </xsl:for-each>
      </xsl:template>
     </xsl:stylesheet>
    And for Page4 menu:
    <xsl:stylesheet
      version="1.0"
        <xsl:variable name="level" select="2"/>
        <xsl:for-each select="$currentPage/ancestor-or-self::* [@level = $level]/* [string(subNavPage4Hide) != '1' and @isDoc]">
          <xsl:choose>
            </xsl:when>
            <xsl:otherwise>
              <li>
                </a>
                 <ul>
                      <li>
                      </li>
                    </xsl:for-each>
                  </ul>
                </xsl:if>
              </li>
            </xsl:otherwise>
          </xsl:choose>
        </xsl:for-each>
      </xsl:template>
     </xsl:stylesheet>
    For Page5 the macros are the same as the last two. Please, advice!!!
    THX, Uros
  • Tom Hare 49 posts 81 karma points
    Sep 28, 2011 @ 12:16
    Tom Hare
    Why do you want to remove the current parent page from the menu? This seems as though it would be very confusing for the user.
    Maybe a more intuitive and efficient solution would be to two separate menus (sub and main), always show the main menu and show the submenu when appropriate. The XSLT for this would be a lot more straightforward than having to track which page the user is on and removing various pages and submenus.
