I use the aspx page of the google analytics for mobile but I can't get it to work. Does anybody have an experience using it.
One step in using it is to add the ga.aspx file in the root folder of our site but I'm getting a page not found error in this.
Hi did you find any solution?
Have you tried creating the ga.aspx page in the root of your website then adding the ga.aspx to the reserved url setting in the web.config?
example
<add key="umbracoReservedUrls" value="~/config/splashes/booting.aspx,~/install/default.aspx,~/config/splashes/noNodes.aspx, ~/ga.aspx" />
Thanks a lot. that works perfact.
Installing mobile analytics in umbraco mobile
example
