  • Thijs 97 posts 117 karma points
    Oct 05, 2011 @ 12:59
    Thijs
    Skin button not showing in UI
    Hi all
    I'm trying to make my own skin for a website. I've watched the umbraco tutorial videos about skinning and I followed the steps. In the videos they press the 'edit skin' button to make changes to a css file for example. This button is missing.. Anyone knows how to make that button visible?
    Thanks anyway
    Thijs
    Oct 05, 2011 @ 13:14
    Thijs
    Sorry for double post but I can't update my previous post.
    The button I'm missing is this one:
    In App_Data/packages/installed/installedPackages.config I marked every package with enableSkinning="True"
    Any help would be really appreciated!
    Thijs
    Oct 06, 2011 @ 09:47
    Thijs
    I solved this one, even though I think the're more suitable solutions. Since you can skin starters kits out of the box I added my masterpage-template id to the templates of the starters kit in 'App_data/packages/installed/installedPackages.config' and linked the custom skin I created in the masterpages folder like they show on the videos.
    Hopefully this helps some people who are also stuck at this.
    Thijs
