hi,
is it ok to remove the footer?
would i get into any copy right issue?
Hey bigboy (that sounds so wrong!)
Do you mean in the front-end? Yes, you are okay to remove the copyright notice from the footer.
Obviously since Umbraco free & open-source, any credit that you can give back to the project/software would be appreciated. ;-)
Cheers, Lee.
ok. thanks!
remove footer "powered by umbraco"?
hi,
Cheers, Lee.
ok. thanks!
