  • eneunaber 10 posts 64 karma points
    Jun 23, 2009 @ 18:51
    eneunaber
    Creating a folder
    I had closed my other topic, before I realized I had another question.
    The previous question was "do I use Media for storing such things as background images?" The answer was to create a folder and put the images inside that folder and reference the folder from your css.
    My follow up question is:
    Do I create this folder under the Web Site or would it go under "Developer" or "Settings"?
    Either way, I'm unsure of how to create a simple folder to put these images under.
  • Tommy Poulsen 514 posts 708 karma points
    Jun 23, 2009 @ 18:58
    Tommy Poulsen
    In case you want a folder for you static images you can create it manually (outside Umbraco, using e.g. a file explorer) where you think it would be appropriate. It could be in the website root (like /images) or whereever you find it appropriate.
    If you want to make subfolder in the media section you can do it as you add new media - but selecting "Folder" as the media type.
    >Tommy
  • Rasmus Lynggaard 118 posts 325 karma points
    Jun 23, 2009 @ 20:18
    Rasmus Lynggaard
    For images etc. referenced by css (or just static images) we never use the media section. We just create a folder in the root of the site and places them in there.
    Jun 23, 2009 @ 20:39
    eneunaber
    I was unsure if I could simply create a folder using the file system or if I had to use Umbraco to create the folder. Seeing as how I can simply create a folder, I'll just do that.
  • steve paxton 2 posts 20 karma points
    Jul 06, 2009 @ 14:38
    steve paxton
    I'm very new to Umbraco (but have been developing in PHP for many years). I've been asked to create a site as a subdomain of a site which has an existing Umbraco installation. I assumed I would be able to create a folder for the new site in Umbraco, but that doesn't seem possible, so I searched for create folder & found this thread. One answer says that I can create the folder outside of Umbraco, which I've done, but it still doesn't appear inside Umbraco. Can someone tell me how I can create a folder to build this site in? Under the create option I only have a number of items which relate to the content in the existing website.
  • Bart de Jonge 29 posts 51 karma points
    Jul 08, 2009 @ 16:39
    Bart de Jonge
    Hi Steve,
    If you want to create a new site under the content folder you should first create the document type (best start with a masterpage). there are some great video's on the umbraco site that show you how to do that.
    hope this helps.
    Bart
  • martin sansom 1 post 21 karma points
    Dec 21, 2010 @ 18:10
    martin sansom
    Go to the media section (bottom left) and ten right click on your media folder (top left) to create a new sub-folder called 'images'.
