  • skiltz 501 posts 701 karma points
    Jun 23, 2009 @ 22:35
    skiltz
    Usercontrol + Required Field Validator
    Just as a test I have a user control like so:
    <asp:TextBox ID="txtSoemthing" runat="server" />
    <asp:RequiredFieldValidator ID="rfvdwdw" ControlToValidate="txtSoemthing" runat="server" ErrorMessage="*" />
    When the page loads I get a jscript error "missing ; before statement" in ff and "Error expected ;" in IE.  Anyone else have RFV working in user controls?
    This is version 4.
    Matthew
  • Bert 128 posts 251 karma points
    Jun 24, 2009 @ 12:32
    Bert
    I would recommend checking your container placeholders in your templates. Do you have a server side form on your page?
    In FF you can use Tools > Error Console and then just click on the error to see the exact place of the error. That might help too.
  • Lee 1130 posts 3088 karma points
    Jun 29, 2010 @ 13:22
    Lee
    I have just had the exact same error explained by Matthew above?  Using 4.0.4.1 and added a simple form with RequiredFieldValidators and now in my FireFox error console I get:
    Error: missing ; before statement
    Line: 208, Column: 4
    Source Code:
    var ctl00_ctl00_ctl00_ctl00_ContentPlaceHolderDefault_ChildContent_MainInnerContent_ctl01_find-a-specialist_3_Req1 = document.all ? document.all["ctl00_ctl00_ctl00_ctl00_ContentPlaceHolderDefault_ChildContent_MainInnerContent_ctl01_find-a-specialist_3_Req
    I'm using the out the box .NET controls?
