Deleted script names still in "Insert Macro" dropdown
I created a script in XSLT then deleted it and recreated it in Razor (several times). When I come to use the "Insert Macro" dropdown I see multiple instances of the same name. Shouldn't they have been deleted when the script was deleted? How can I clean this up?
That's probably because you have not deleted the macro but just deleted the xslt file.
When you create a xslt within the developer section in Umbraco there's automatically also being created a macro that holds a reference to the file, unless you uncheck this option during the creation process.
Therefore you need to go into the developer section and expand the macro folder where you can see the macros available and then delete those you don't need anymore.
Craig
Hi Craig
Hope this helps.
Thanks Jan, never thought to look, but I will in future (blush),
Craig
Hi Craig
You're very welcome - glad that it helped :-)
Please remember to mark the issue as solved.
