  • Umbraco 137 posts 294 karma points
    Oct 16, 2011 @ 23:17
    Umbraco
    Macro container property reports "Only 0 macros are allowed" but 2 macros are allowed
    I have just configured a new Data Type using the Macro Container control. I have selected two macros under the data type's Allowed Macros setting.
    Now when I add a property of this data type to a document type and then try to use the control, I can't add any macros and the control renders "Only 0 macros are allowed"
    Do I need any other configuration for this to work? The macros I have allowed are both Razor macros, both located in a subfolder of the ~/macroScripts folder, and one of them can also be used and rendered in the editor.
  • Bruce Canino 21 posts 42 karma points
    Apr 26, 2012 @ 00:51
    Bruce Canino
    Did you put a number in for
    Max Number
    field?
  • Dave Clinton 31 posts 106 karma points
    Jul 31, 2013 @ 23:02
    Dave Clinton
    Aha not specifying a max number is what caught me out as well, thanks Bruce :)
  • Rahmathullah 7 posts 85 karma points
    Sep 15, 2014 @ 12:20
    Rahmathullah
    where to specify this?
    Sep 15, 2014 @ 15:41
    Dave Clinton
    @Rahmathullah
    If you go to Developer > Data Types and select Macro Container then at the bottom of the page (below the Allowed Macros list) you'll see a field to specify the maximum number of macros that are allowed.
