I'm new to Umbraco and have installed it on my PC to get used to it. Having said that, I am a Joomla power user so do have some idea of using a cms.
So I've installed my site and set it up using the business starter kit that comes with the install and I've used the umedia skin.
It all looks great, but I'm presented with the problem of the right columns. There are two boxes in the right column, one that says 'edit the right column' with a link that says 'find more packages' and the other that says something about using xslt and a link to 'Using xslt'
I'm assuming this template works as-is. If so, how do I quickly and easily 'edit the right column' without coding? Is it possible?
Umedia template with business starter kit
Thanks in advance.
I have not heard back regarding this either, and am wondering how to do so.
