  • Evan 3 posts 23 karma points
    Oct 19, 2011 @ 10:28
    Evan
    Using "HTML EDIT" to moditfy img src,after save, img src would not change
    step 1, i use "insert/edit image" to add an img
     ex :<img src="/media/282342/check_mark.jpg" alt="Check _mark" width="22" height="17" rel="0" />
    step 2.I modify src by "html edit"
    <img src="/2008/media/282342/check_mark.jpg" alt="Check _mark" width="22" height="17" rel="0" />
    and that src isn't inside the web, so that will be an broke path
    step3. save
    step4, using "html edit" the path change to "<img src="/media/282342/check_mark.jpg" alt="Check _mark" width="22" height="17" rel="0" />"
    if i need to keep the url (even that is invalid) how could i do
  • Rodion Novoselov 694 posts 859 karma points
    Oct 19, 2011 @ 11:29
    Rodion Novoselov
    Hi. You can change the TidyEditorContent setting in umbracoSettings.config to False. It will make RTE to keep your html more or less 'as is'.
