  • Mike 16 posts 32 karma points
    Jun 24, 2009 @ 14:35
    Mike
    Per article comments
    Hi!
    I'd like people to leave comments on a per article basis.
    Anyone have ideas how to implement this?
    br,
    mike
  • Tommy Poulsen 514 posts 708 karma points
    Jun 24, 2009 @ 14:42
    Tommy Poulsen
    Hi Mike, you could do this by adding a doc2form macro to your article template. The doc2form would make your comment form (with author, content etc.) and then automatically create a new comment node, e.g. as child of the article node.
    Your article template should display all comment-childs - this can easily be done as a xslt macro.
    - a bit rough help, maybe, but maybe enough to get you started,
    >Tommy
  • Jakob Andersen 2 posts 1 karma points
    Jun 24, 2009 @ 15:21
    Jakob Andersen
    There is a pretty good example that even provides threading in this blog post http://www.geckonewmedia.com/blog/2009/6/4/nested-(threaded)-comments-in-umbraco-with-doc2form-and-jquery based on the umbraco blog package
    Jun 24, 2009 @ 18:11
    Mike
    Works nice :-)
    Thanks a lot!
  • trfletch 598 posts 604 karma points
    Jul 10, 2009 @ 17:54
    trfletch
    I am trying to setup a comment form on one of my sites, how do I make doc2form setup the node as a child node for the current article?
    Jul 10, 2009 @ 18:39
    Dirk De Grave
    Do you mean that you want to comment to become child node of the article for which a comment is being submitted?
    If so, this is just a macro property settings:
    In that case, all comments for an article (if macro is droppend onto template that renders the article) will become child nodes of that specifi article...
    Hope this helps.
    Regards,
    /Dirk
    Jul 13, 2009 @ 13:02
    trfletch
    Thanks Dirk, just what I needed.
  • Simon Probert 21 posts 45 karma points
    Jul 13, 2009 @ 14:16
    Simon Probert
    You might also consider using the Honeypot technique as mentioned on the old forum:
    http://forum.umbraco.org/yaf_postst6257_Doc2Form-HoneyPot-technique.aspx
    It seems to work pretty good at keeping the evil spambots away :)
  • Eran 292 posts 436 karma points
    Dec 30, 2010 @ 02:44
    Eran
    the new URL for the blog post about implemets doc2form is located here:
    http://www.geckonewmedia.com/blog/2009/6/4/nested-%28threaded%29-comments-in-umbraco-with-doc2form-and-jquery
  • Chris 69 posts 75 karma points
    Dec 30, 2010 @ 04:41
    Chris
    I haven't used it yet, but you may also consider the UComment package created by Tim (including admin panel and spam filtering)...
    http://our.umbraco.org/projects/collaboration/ucomment
