Can I create language variations of a label for a DocumentType field?
I have a project that will allow users from different cultures to use the Umbraco UI and so I need the labels (and descriptions) of fields within a DocumentType (e.g. Event or News Article) to appear in the relevant language.
Is this possible? I know that I can change the language of the UI but obviously this will not affect the the field labels that I have created for my document types.
The only way I can think of doing this is by creating a new set of datatypes which use a custom dictionary (or the Umbraco dictionary).
Thanks.
Hi Kieron,
Yes, you can use a dictionary item for your Property Names,
ie: #BodyText
I am not 100% sure if it works on the Descriptions or Tabs though, you'll have to test :)
Note I think you'll also need to set each user's language in the User settings.
-Tom
Hi Kieron,
Have a look at this: http://our.umbraco.org/wiki/how-tos/how-to-localize-umbraco-backend-document-types
/Dirk
Nice and quick! Many thanks for that Tom, I'll give that a go.
Would still love to know about descriptions and tabs. Anyone?
Should be similar, add '#' and make sure to translate the tabs. I'm not sure about descriptions to be honest.
/Dirk
Yes, thanks for the answers guys. It works for field labels, descriptions and tabs in the same way.
Much appreciated.
