Audit Trail from context menu appears without permissions
how can i disable Audit Trail from context menu? I already set the permissions to uncheck, but it continues there...
I already saw in DB that the user add or not the permission that i change in the user section but in the context menu in content tree, it appears always, no manner what.
Doesn't look as a forum bug.. so moving to another category...
As for the original question... could be a bug, if you can repro this on a 2nd install, report it on Codeplex and make sure to mention umbraco version as well!!
Already Done! :) I'm hopping for a new version of the umbraco, with this problem solved and the content preview too (that i already saw that was fix in a nightly version). I guess these are the major problems that i found using 4.7.1 umbraco version. You are doing a great work, so continue, like that.
Regards,
Mário
/Dirk
Mario,
Confirmed, audit trail is not removed from the context menu, even if not checked. Can you log on Codeplex?
/Dirk
Hi again,
Best Regards,
Mário
