  • Phillip Ng 148 posts 250 karma points
    Oct 21, 2011 @ 01:18
    Phillip Ng
    Change sort order in Rollback function
    Hello everyone
    I have a client that is requesting the Rollback function on a content page start with most recent to least recent. Is there an easy way to do this? I couldn't find anything immediately so did some poking around and found a rollback.aspx that uses a rollback.aspx.cs. The code-behind has been compiled however so we can't edit it. Any suggestions? Thanks in advance!
    Phil
  • Rodion Novoselov 694 posts 859 karma points
    Oct 21, 2011 @ 08:29
    Rodion Novoselov
    Hi. The drop down list with all versions is filled from the array that's returned by the Document.GetVersions() method. And this method returns those with the predefined order - from the oldest to the newest ones. So, I think it's not possible to alter this behaviour without modifications to the core. However, I suppose that you could do it at least without rebuilding the whole umbraco - you can place a small piece of javascript code to the /umbraco/dialogs/rollBack.aspx file that will revert the order of the items in the dropdown list on the client as this page is loaded.
    Oct 21, 2011 @ 08:47
    Rodion Novoselov
    Below is the sample of possible code:
    //<![CDATA[
        $(function() {
            var opt0 = $('#<%= allVersions.ClientID %> option').first();
            opt0.siblings()
                .remove()
                .each(function() {
                  $(this).insertAfter(opt0);
    </script>
    Nov 01, 2011 @ 18:07
    Phillip Ng
    That's awesome -- works like a champ! Thank you very much Rodion!
