  • Dominic Brown 91 posts 111 karma points
    Oct 24, 2011 @ 14:31
    Dominic Brown
    SliderImageNav (buttons) u.MediaSlider
    I've created a site using the business template with the standard u.media slider installed, i've made a few changes to the layout and image sizes etc but i am having trouble with the image nav bar (the little buttons that let you move to different images in the slider). I cannot seem to get the nav button to appear on top of the images, its always behind which mean its not even visible to the end user.
    I've tried z-index but this has no effect, can anyone help?
    I'll add my CSS for the slider, please forgive me if its not very good, i am new to this.
    thanks in advance
    #imageshadow {
    position:relative;
    bottom:100px;
    #slider {
      position:relative;
    bottom:40px;
        overflow: hidden;
      width: 960px;
    height:430px;
      clear: both;
      overflow:visiabl
          #slider .imageSliderInfo{
            color: #FFF;
            width: 960px;
            height:50px;
            position:relative;
            top:320px;
            background-color:#000;
            #slider .imageSliderInfo h2{
              color: #FFF;
              font-size: 26px;
            #slider .imageSliderInfo p{
              color: #FFF;
              font-size: 20px;
            padding:10px;
          #slider .imageSliderImage{
            position:relative;
        bottom:110px;
            height:380px;
            #slider .imageSliderImage img{
              border: 0px #000 solid;
       #slider #imageSliderNav{
          position:relative;
          bottom:0px;
          float: left;
          overflow: auto;
          text-align: left;
          width: 540px;
          padding-top:45px;
          padding-left:16px;
          #slider #imageSliderNav a{
            background-image: url(/images/imageSliderNav.png);
            background-position: center center;
            background-repeat: no-repeat;
            background-color: #dee4e4;
            text-indent: -9000px;
            display: inline-block;
            height: 20px;
            width: 20px;
            #slider #imageSliderNav a.activeSlide{
    Oct 24, 2011 @ 15:03
    Dominic Brown
    here is a screen shot of the imageslider for reference
  • Rodion Novoselov 694 posts 859 karma points
    Oct 24, 2011 @ 23:32
    Rodion Novoselov
    Hi. I haven't looked into your CSS carefully, but as a first thought - did you account the thing that z-index works only for positioned elements?
    Oct 25, 2011 @ 12:23
    Dominic Brown
    Hi, thanks for your reply.
    I have everything set to position:relative; and i've been using the left: right: top: bottom:  method for posistioning things, is this the issues do you think?
    Oct 25, 2011 @ 20:43
    Rodion Novoselov
    Dominic, try and remove "overflow:hidden" from
    #slider {
      position:relative;
    bottom:40px;
        overflowhidden;
      width960px;
    height:430px;
      clearboth;
      overflow:visiabl
    and situation will become much clearer.
    The slider nav is actally there, but it went down and "overflow:hidden" of the parent div hid it.
    Oct 25, 2011 @ 21:36
    Dominic Brown
    yeah i've tried changing that to visible before but all it did was move things around the nav button were stiull underneath the images :oS
    Oct 25, 2011 @ 22:03
    Rodion Novoselov
    Oh. I have tried and it seems that all you need is just to add
    #imageSliderNav {
      position: relative;
      top: -64px;
      z-index: 100;
    to the end of an original custom.css file. Than you'll just need to edit the button png image and modify some background colors to maintain proper transparency.
    Oct 25, 2011 @ 22:47
    Dominic Brown
    wow thanks alot!!
    i've put it in like this and its now on top and in the top left of the image
    #slider #imageSliderNav {
      position: relative;
    top: -455px;
      z-index: 100;
            height: 20px;
            width: 20px;
    How does this work? I was told never to use minus figures in CSS. Glad it works tho, its been driving me mad for ages now. Thanks again!!!
    Oct 25, 2011 @ 23:08
    Rodion Novoselov
    That's simple. Simply, position: relative means that everything is ok but you just want somehow to shift the element from the 'normal' flow. In your case you just take your #imageSliderNav and shift it upside by "top: -NNN". It's strange to hear about avoiding usage of negative values in CSS since they're very important for some standard methods. For instance, look at the following (i think most-known) method of building transparent rounded corners:
    http://www.schillmania.com/content/entries/2006/04/more-rounded-corners/
    It's completely based on negative margins.
    Oct 25, 2011 @ 23:26
    Dominic Brown
    Well it was my boss that told me that, he is a silverlight dev man with basic CSS skills, maybe thats why hehe
    thanks for the link, will give it a good read tomorrow morning!!
    fyi, for rounded boarders i've been using:
    border: 1px solid #696;
    padding: 60px 0;
    text-align: center; width: 200px;
    -webkit-border-radius: 100px;
    -moz-border-radius: 100px;
    background: #EEFF99;
    behavior: url(/PIE.htc);
