  • Robert Dolman 22 posts 42 karma points
    Oct 24, 2011 @ 17:23
    Robert Dolman
    Restrict media picker
    Is it possible to restrict the media picker to only list files of a certain media type i.e. 'Image' so the user can only select images from the media library?
    Oct 24, 2011 @ 17:32
    Hi Robert
    The default media picker does not support this out of the box.
    Maybe you should have a look at the DAMP package here: http://our.umbraco.org/projects/backoffice-extensions/digibiz-advanced-media-picker - It look like it supports this kind of restriction.
    Oct 24, 2011 @ 18:05
    Robert Dolman
    Thanks for the info Jan, I'll take that for a test spin.
