I would like to copy a member type so I can create a similar member type. This will need to be done in the development environment then again in staging/production.
Is there a way to do this in Umbraco or with a tool?
I'm not aware of any tool that can handle the export/import of membertypes in any umbraco v4.x version and it's not supported out the box in Umbraco. But perhaps you should be able to write some custom code to achieve it using the API?
Copy or export/import member type? 4.0.2
Hi Pete
There is not tool to do that, Using the API will take a lot longer than doing by hand I'm afrraid.
Richard
