The earlier poster also suggests adding the mime type to the config file - I'm not sure how to do this. Would anyone mind pointing me in the right direction - this could be what's causing the problem.
I managed to get this working - I was adding all the content, including the <staticContent></staticContent> tags. These were in place already, all I had to add was…
<!-- HTML4 Web font mime types --> <!-- Remove default IIS mime type for .eot which is application/octet-stream --> <remove fileExtension=".eot" /> <mimeMap fileExtension=".eot" mimeType="application/vnd.ms-fontobject" /> <mimeMap fileExtension=".otf" mimeType="font/otf" /> <mimeMap fileExtension=".woff" mimeType="font/x-woff" />
@font-face problems
Hi Folks,
I'm trying to get some fonts on my site and I'm having problems - my fonts aren't displaying. Here's what I've done so far:
Added the fonts directly to the css folder as suggested in an earlier posting and called it with the following:
@font-face {
font-family: Lato ;
src: url(lato-regular.eot); /* IE */
src: local("lato-regular.ttf"), url( lato-regular.ttf ) format("truetype"); /* non-IE */
src: local("lato-regular.woff"), url( lato-regular.woff ) format("woff"); /* IE9 */
.menu {
width:950px;
height:42px;
font-family: "Lato";
font-weight:normal;
text-transform:uppercase;
font-size:11px;
background-color:#CCC;
The font doesn't show up.
Any help will be greatly appreciated.
Darren
Hi Darren
You can add the mime-type in the web.config file in the
<system.webServer></system.webServer> section you can add this
<staticContent>
</staticContent>
I will also recommend that you use the http://www.fontsquirrel.com/fontface/generator service to generate the fonts for you if you have not done so already.
Hope these pointers help a bit :)
Thanks again, Yan. I'll give this a try!
Darren
Hi Yan,
I get the following error when I insert this code:
It then locks me out of the site.
Darren
Hi Yan,
Darren
Hi Darren
Yes, and it can sometimes be a bit confusing where the elements should be added but happy to hear you figured it out :)
Remember to mark the post as solved.
Cheers
