  • anthony hall 222 posts 536 karma points
    Oct 27, 2011 @ 10:40
    anthony hall
    tinymce is putting content in <pre> tag
    I have alot of content inside psd files. When this text data is copied into a Rich Text editor it put the content inside a <pre> tag. Is there a way i can force it to create <p> tags instead?
  • Ivan 139 posts 302 karma points
    Oct 27, 2011 @ 13:32
    Ivan
    Try to include pre inside <invalidElements> section of tinyMceConfig.config file located under "config" folder.
    You can also check the following topic:
    http://our.umbraco.org/wiki/how-tos/customizing-the-wysiwyg-rich-text-editor-%28tinymce%29/allow-any-markup-in-the-tinymce-editor
    Remember to "touch" your web.config file to make Umbraco reload it's configuration.
    Bye!
    Ivan
    Oct 27, 2011 @ 13:41
    anthony hall
    thanks. I did as you suggested and it worked.
     <invalidElements>font, pre</invalidElements>
