Hi All,
Am having a server error after setting my domain hostname and set useDomainPrefixes to "true".
When i click on any node for example
mydomain.com/en/test.aspx, I get the following Error Message any thoughts why?
Got the working i somehow forgot to set "umbracoHideTopLevelNodeFromPath" to false in the web.config
<add key="umbracoHideTopLevelNodeFromPath" value="false" />
Multilanguage Website
Hi All,
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
