  • Camron Tucker 11 posts 31 karma points
    Oct 28, 2011 @ 18:07
    Camron Tucker
    404 redirect to external site
    We have a website that on a 404 error we need to redirect to a slightly different url, i.e. www.domain1.com/test on a 404 needs to redirect to www.domain2.com/test. It needs to preserve everything after the .com. What would be the best way to handle this in Umbraco?
    Oct 28, 2011 @ 18:49
    Rich Green
    Hey Camron,
    I'm pretty sure you would have to add your own HTTPhandler to accomplish this, shouldn't be too tricky.
    Maybe download the uComponents source and have a look at the source for http://ucomponents.codeplex.com/wikipage?title=SearchForPageNotFound
    Rich
  • Mike Chambers 636 posts 1253 karma points c-trib
    Oct 28, 2011 @ 23:00
    Mike Chambers
    or write your own custom 404 handler something like this... (http://our.umbraco.org/wiki/how-tos/how-to-implement-your-own-404-handler was were I got the inspiration)
    NB untested code below...
    public class Custom404Redirect : INotFoundHandler
            #region INotFoundHandler Members
            public bool CacheUrl
                get
                    return false;
            public bool Execute(string url)
                // add entry to the log for debug purposes.
                umbraco.BusinessLogic.Log.Add(umbraco.BusinessLogic.LogTypes.NotFound, _redirectID, "404 Redirect - " + HttpContext.Current.Request.Url);
                // can set as a 301 or anything else depending on what you want
                //HttpContext.Current.Response.Status = "301 Moved Permanently";
    // might need to revisit this to your own requirements.
                HttpContext.Current.Response.AddHeader("Location", "WWW.DOMAIN2.COM/"+HttpContext.Current.Request.Url);
                return true;
            #endregion
    and add to the 404handlers.config
    <?xml version="1.0" encoding="utf-8" ?>
    <NotFoundHandlers>
    ...other handlers...
      <notFound assembly="XXX" type="Custom404" />
    .. leave the umbraco custom handler to catch all
        <notFound assembly="umbraco" type="handle404"/>
    </NotFoundHandlers>
    Oct 28, 2011 @ 23:03
    Hi Camron
    I'm not sure but maybe you could add a rewriting rule in the UrlRewriting.config file, which is found in the "config" folder? I'm not expert with url rewriting at all just thought that I would mention that it might be possible?
    Oct 31, 2011 @ 18:04
    Camron Tucker
    Thanks everyone for your replies. I ended up writing my own 404 handler implementing the INotFoundHandler like Mike and Rich suggested, which was pretty slick and easy.
  • Atoosa Khoda 96 posts 148 karma points
    Feb 04, 2013 @ 05:32
    Atoosa Khoda
    Hi There Camron. I'm having a similar senario, would like to redirect to an external domain via 404 handler. What did you set the _redirectID? Generally my handler is working if i redirect to an node within the umbraco, but can't get it working for an external 301 with no redirect id.
    This is what i've used:
    HttpContext.Current.Response.StatusCode = 301;
            HttpContext.Current.Response.AddHeader("Location", "WWW.DOMAIN2.COM/somepage");
                return true;
    Any luck?
    Thanks.
  • SinkyPars 132 posts 175 karma points
    Jun 09, 2013 @ 20:21
    SinkyPars
    Bit of a bump here, I too have a similar issue. If the domain is not in my host names I would like to show a 404, can anyone please advise on how to do this?
    Scott
