  • Sherry Ann Hernandez 320 posts 344 karma points
    Oct 31, 2011 @ 10:15
    redirecting a hostname to a specific page
    I have two hostname in one umbraco installation and the other hostname directs to a specific page. How can I redirect http://www.site.com to http://www.site.com/page1.aspx and http://www.site/com/ar to http://www.site.com/ar/page1.aspx
    Any ideas?
  • Jacob Jensen 40 posts 60 karma points
    Oct 31, 2011 @ 10:24
    Jacob Jensen
    in urlrewriting.config:
    <add name="Site1"
                  virtualUrl="^~/"
                  rewriteUrlParameter="ExcludeFromClientQueryString"
                  destinationUrl="~/page1.aspx"
                  ignoreCase="true" />
            <add name="Site2"
                  virtualUrl="^~/com/ar"
                  destinationUrl="~/ar/page1.aspx"
  • Fuji Kusaka 2203 posts 4220 karma points
    Oct 31, 2011 @ 10:26
    Fuji Kusaka
    You could add a Property in your Document Type with alias "umbracoRedirect", Type Content Picker.
    Then under your Content Section choose the page under which you want the page to be redirected to.
    Oct 31, 2011 @ 12:36
    Hi Jacob,
    The virtual url ~/ will redirect the main hostname right? But in my umbraco installation I setup two hostname. the ~/ pertains to the first hostname and the 2nd hostname is www.site2.com
    Hi Fuji,
    The umbraco redirect doesn't recognize the querystring that I have. That's why I didn't use it.
    Oct 31, 2011 @ 13:24
    Fuji Kusaka
    When you go you under your Content Section and choose the document Type cant you pick up a node?
