  • Zoppo 3 posts 20 karma points
    Jun 25, 2009 @ 10:44
    Zoppo
    How to change "Max Upload folder size "
    Hi there!
    I`m looking for the setting where to increase/set  the max. Folder Size of <span id="FolderDescription">/UserFiles/File/</span>. It`s now set to 100 MB.
    Thanks in advance and best regards,
    Zoppo
    Jun 25, 2009 @ 11:03
    Ismail Mayat
    2
    Do you mean in media section the actual max file size of files that can be uploaded? If so then that is .net setting in web.config namely
    <httpRuntime  maxRequestLength="10000"
    executionTimeout="600"  />
    Increase your size to whatever you like. Please note if file size is exceeded it will still try to upload then give you .net error.
    Regards
    Ismail
    Jun 25, 2009 @ 11:52
    Zoppo
    Oh, i`m sorry... my mistake. It was a config setting in Cute Editor.
    Ismail - Thank you for your help.
    Best regards,
    Zoppo
