  • Connie DeCinko 931 posts 1160 karma points
    Nov 03, 2011 @ 16:52
    Connie DeCinko
    Sequence contains no elements
    What is this error? I started yesterday, went away and is back again today.
    [InvalidOperationException: Sequence contains no elements]
    System.Linq.Enumerable.Single(IEnumerable`1 source) +379
    Examine.DictionaryExtensions.ReadFromDisk(Dictionary`2 d, FileInfo fi) +399
    Examine.LuceneEngine.IndexerExecutive.GetLCK() +50
    Examine.LuceneEngine.IndexerExecutive.TimestampLck() +103
    Examine.LuceneEngine.IndexerExecutive.get_IsExecutiveMachine() +79
    Examine.LuceneEngine.Providers.LuceneIndexer.SafelyProcessQueueItems() +23
    Examine.LuceneEngine.Providers.LuceneIndexer.AddNodesToIndex(IEnumerable`1 nodes, String type) +520
    Examine.LuceneEngine.Providers.LuceneIndexer.ReIndexNode(XElement node, String type) +188
    Examine.ExamineManager._ReIndexNode(XElement node, String type, IEnumerable`1 providers) +93
    UmbracoExamine.UmbracoEventManager.Document_AfterSave(Document sender, SaveEventArgs e) +373
    umbraco.cms.businesslogic.web.SaveEventHandler.Invoke(Document sender, SaveEventArgs e) +0
    umbraco.cms.businesslogic.web.Document.Save() +336
    umbraco.cms.businesslogic.web.Document.MakeNew(String Name, DocumentType dct, User u, Int32 ParentId) +1480
    umbraco.contentTasks.Save() +76
    umbraco.presentation.create.dialogHandler_temp.Create(String NodeType, Int32 TypeId, Int32 NodeId, String Text) +755
    umbraco.cms.presentation.create.controls.content.doCreation() +225
    System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +154
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3691
  • daveb.84 21 posts 46 karma points
    Nov 04, 2011 @ 15:55
    daveb.84
    I'm having the same problem after I've just upgraded Examine to the latest version off codeplex. (Version 1.3 - Examine.dll assembly Version=0.1.3.2922)
    It seems the root of the problem is in Examine.DictionaryExtensions.ReadFromDisk(this Dictionary d, FileInfo fi)
    public static void ReadFromDisk(this Dictionary d, FileInfo fi)
        d.Clear();
        using (FileStream fileStream = new FileStream(fi.FullName, FileMode.Open))
            using (StreamReader streamReader = new StreamReader(fileStream, DictionaryExtensions.DefaultFileEncoding))
                XDocument xDocument = XDocument.Load(streamReader);
                if (xDocument.Root != null)
                    foreach (XElement current in xDocument.Root.Elements())
                        d.Add((string)current.Attribute("key"), current.Nodes().OfType().Single().Value);
    The call to Single<XCData>() doesn't have any elements so is throwing an exception
    I'm rolling back to my previous version of Examine for now
    Nov 04, 2011 @ 16:54
    Connie DeCinko
    I figured out the issue.  When you upgrade Examine, you have to delete the Examine collections, folders and all.  The format is just different enough that Examine is not smart enough to deal with it.  Odd thing, is I thought I did that and things worked fine, then the next day, error.  Deleted the collections and all is good.
    /appdata/examineindexes/
