  • Ben Norman 167 posts 276 karma points
    Nov 03, 2011 @ 22:45
    Ben Norman
    permissions within Content Section
    If I implement a multisite instance with 2 or more site, can you create a user for a specific site and restrict access to just one site?
    Can you remove the other sites from view?
    Can you do the same in the Media Folder?
    Nov 03, 2011 @ 23:21
    Hi Ben
    With v4 of Umbraco it is possible to restrict access to the sites in the content section so that user a can only access site a and user b can only access site b.
    However you can't unfortunately not set the same permissions for the media section so the media section is shared between the sites meaning that user a can access the same media as user b, which is not ideal.
    This is going to change in version 5 of Umbraco. Matt Brailsford has written a blogpost about Why permissions in Umbraco v5 rock!
