  • dominik 711 posts 733 karma points
    Nov 08, 2011 @ 14:51
    dominik
    folder in url
    i am using the following structure
    en
    - home.aspx
    if i am now opening the url it always redirects to:
    domain.com/home.aspx instead of domain.com/en/home.aspx
    I have set the hostnames but this does not fix this problem
    i am using umbraco 4.7.0
    Any solution?
    Nov 08, 2011 @ 15:20
    dominik
    I found it out
    If i name the alias of the folder to "Rootfolder" instead of "Root" it works.
    So it looks like it must use the word "folder"?
  • Rodion Novoselov 694 posts 859 karma points
    Nov 08, 2011 @ 21:13
    Rodion Novoselov
    Hello, Dominik. It seems that you just need to set the 'umbracoHideTopLevelNodeFromPath' setting in the web.config file to 'false' (default is 'true').
    Nov 09, 2011 @ 07:44
    dominik
    no this paramater has not solved this issue. Also after republishing complete site. If i rename the documentType "Root" to "RootFolder" it works
