If I set a unpublish date the item is not unpublished. Is this an error?
I set unpublish date for example to:
2011-11-09 09:08
But item is not removed from the website
Are you using the Remove At Property to unpublished the node?
yes i use remove at property
I have found I need to set a Remove At date/time to maybe 15 minutes ahead.
Alternatively, try Unpublish, then set Publish At to a time 15 minutes ahead, and Remove At to a time 1 minute after that. I found that worked.
By the way, click Save (not Save and Publish) icon.
Unpublish date is not working
2011-11-09 09:08
