  • atze187 160 posts 215 karma points
    Jun 26, 2009 @ 11:50
    atze187
    Open custom dashboard tab on load
    i have just setup some user controls for use with the dashboard and added them to some tabs. Is there a way to set the default tab to expand as currently all my tabs are collapsed?
    André
    Jun 26, 2009 @ 11:58
    Dirk De Grave
    André,
    I'm not sure what you mean by a 'tabs are collapsed'? Can you elaborate on that?
    Dirk
    Jun 26, 2009 @ 12:12
    atze187
    The tabs' contents are not visible by default (Watch it), i have to click one of the tabs to see something. I would like to have one (preferrebly one chosen by me or the first tab) tab to show its content when the dashboard loads.
    André
  • rorythecheese 110 posts 56 karma points
    Jun 26, 2009 @ 12:33
    rorythecheese
    Yeah i get this in firefox(pc), works fine in chrome though.
    Seems to be because the .tabpage css class starts off with a display:none; . I'd guess there's some javascript that switches it somewhere which firefox has a problem with.
    Only a small thing but should probably be put on codeplex anyway.
    Jun 26, 2009 @ 12:35
    Dirk De Grave
    Oh, ok, I get the picture. I'm pretty sure that's some kind of bug, as when refreshing the page when clicking the 'Content' section, you'll get the complete tab visible on screen. It's annoying, so I would recommend to add a work item on Codeplex (that's where all issues should be reported) and vote for it.
    I've been experiencing this as well, so I know you're not alone... but as I found a workaround, I never got to complain about it.
    /Dirk
  • fed 199 posts 70 karma points
    Jun 26, 2009 @ 14:35
    fed
    What's your workaround Dirk?
    Jun 26, 2009 @ 14:50
    Dirk De Grave
    fed,
    Refreshing the section does it for me.
    Dirk
    Jun 26, 2009 @ 15:08
    atze187
    Thank you, that enough for me, as the tabs contain only some admin-type of information.
    André
