  • olst 69 posts 88 karma points
    Nov 10, 2011 @ 12:53
    olst
    captcha for nforum
    Is there a captcha solution for posting in nforum ? if not, is there a recommended way to get this fumctionality into nforum, maybe a tutorial, package or something similar ?
    Thanks.
    Nov 10, 2011 @ 12:56
    Ismail Mayat
    You could use recaptcha http://www.google.com/recaptcha should be able to drop it on your template?
    Regards
    Ismail
    Nov 10, 2011 @ 14:43
    olst
    Hi Ismail and thanks for the reply.
    This is indeed what I am looking at, but how is it possible to implement it with a new post in nforum, since the form submit it is done in ajax using base method.
    How is it possible to use the recaptcha on the client side ?
    Nov 10, 2011 @ 15:25
    Ismail Mayat
    oslt,
    Not used nforum so no idea however you might be better off posting directly in nforum our.umbraco forum http://our.umbraco.org/projects/website-utilities/nforum
    Regards
    Ismail
