I have a site which needs to be setup as following:
- www.hostheader.com - contains pages for the uk - www.hostheader.com/usa - contains pages for the usa - www.hostheader.com/italy - contains pages for italy
Ideally in my content tree I'd like to have the following:
Content - UK Site - USA Site - Italy Site
Does anyone know whether it is possible to setup my site in this way? How would I add the hostheaders for these sites. At the moment I have it setup as:
Where the USA and Italy sites are children of the UK site.
You should setup your site with each top level node as a diferent language. Don't make a language site a child of another language site :) If you make the UK-site the first node, Umbraco will uses www.hostheader.com as the UK site
Adding Virtual Directories in Umbraco
Content
- UK Site
- USA Site
- Italy Site
Content
- UK Site
- USA Site
- Italy Site
Aileen
By managing domains you can add the hostheaders.
Thijs
But what if my hostheader is the same for all 3 sites?
Cheers
Aileen
If you use this structure you can access the site like this
Content
- UK => www.hostheader.com OR www.hostheader.com/uk
- USA => www.hosteader.com/usa
- Italy=> www.hostheader.com/italy
This is what you want to accomplish?
If you uses children you will have stuff like www.hostname.com/uk/italy ...
just use the 'manage hostnames' on the top nodes :)
Yeah - that's exactly what I want. I tried it and it didn't work but now it's working all of a sudden :) Thanks for your help!
Hi Thijs
I thought that this was working but unfortunately not. I'm just getting a 404 when I try to access the page. Any ideas?
Cheers
Aileen
Make sure that in your umbracoSettings.config the following line is present:
This post might also be helpful.
Hope this fixes your problem,
Thijs
hmmm - still no luck
I'm sorry then I don't know what the problem is.. I hope someone else read this post and can help you further..
Thijs
Thanks for your help anyway!
Aha - fixed it. I needed to do the following:
Glad you fixed it :)
