  • Lee 95 posts 115 karma points
    Nov 15, 2011 @ 12:00
    Lee
    ASP.net form with XSLT data source
    I have created a form which in ASP.net which I would like to place a DropDownList component.
    I then want to populate the list with a series of nodes using XSLT
    So I created my XSLT:
    <option value="{@id}"><xsl:value-of select="@nodeName"/> </option>
    I know want to add this to my ASP.NET page.
    After searching I found this snippet, but don't understand how I can link it up:
    <asp:DropDownList ID="DropDownList1" runat="server" DataSourceID="XmlDataSource1"
    DataTextField="text" DataValueField="value"></asp:DropDownList>
    <asp:XmlDataSource ID="XmlDataSource1" runat="server" DataFile="~/App_Data/Users.xml"
    TransformFile="~/DropDownConverter.xsl"></asp:XmlDataSource>
    Any advice would be greatly received!
  • Michael Latouche 504 posts 819 karma points MVP 5x c-trib
    Nov 15, 2011 @ 13:38
    Michael Latouche
    Hi Lee,
    Where are you getting the list items from? Are these Umbraco Nodes?
    One way of doing would be to put your XSLT logic to render the dropdownlist into a macro, and then integrate that macro in your ASP code.
    Hope this helps.
    Michael.
    Nov 15, 2011 @ 14:14
    Lee
    They are child nodes, so how would you integrate the macro into the asp code?
    Nov 15, 2011 @ 14:36
    Michael Latouche
    Hi Lee,
    Let's say that you call your macro "MyListMacro", then you can integrate it in your asp code like this:
    <umbraco:Macro Alias="MyListMacro" runat="server"></umbraco:Macro>
    Michael.
    Nov 15, 2011 @ 15:51
    Lee
    Cool...
    But I've got
    System.Xml.XmlException: 'asp' is an undeclared prefix. Line 20, position 7.
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
      xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:fulltextsearch.search="urn:fulltextsearch.search" xmlns:fulltextsearch.helper="urn:fulltextsearch.helper"
      exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets fulltextsearch.search fulltextsearch.helper ">
    <xsl:template match="/">
    <!-- The fun starts here -->
      <options>
    <xsl:for-each select="$currentPage/Vacancies [@isDoc]">
         <asp:ListItem><asp:value-of select="@nodeName"/></asp:ListItem>
    </xsl:for-each>
      </options>
    </xsl:template>
    </xsl:stylesheet>
