  • Stephen 204 posts 246 karma points
    Nov 22, 2011 @ 13:05
    Stephen
    Non publish items
    I've built a form in .net which talks to the umbraco ui and when a user completes the form it gets added as a new item within a "settings" folder i created under the content node.
    Everything works but CMS user still have the option to "Save and publish" which i dont want...is there a way to disable this?
    Many thanks,
    S
  • Hundebol 167 posts 314 karma points
    Nov 22, 2011 @ 13:34
    Hundebol
    Hi Stephen,
    As far as i know you can not hide these. But under user settings, you can see what backend-users are able to see.
    For instance, this content three
    Normal site
    -- Frontpage
    ---- Subpage
    ------ Sub-Subpage
    Settings site
    -- Subpages created via the .net control
    In this structure, you can tell umbraco that your backend administrator can only see the "normal site" structure.
    Best regards,
    Brian
    Nov 22, 2011 @ 13:57
    Stephen
    thanks for the feedback Brian. In the doc type for my form responses i have give the client the ability too add notes against the enquiry. So i want them to see the enquiry, add notes and save but NOT publish. Would defo not want them publishing details about enquiries...
    S
