I'm following the instuctions on umbracco tv for setting up search and it works. However I've justed add a field to the textpage template which will be a summary of the page. I want to display in the list of search results like so:
But it just throws an error that the key isn't present in the dictionary. Is there something I need to do to the index configs? I can access "bodyText" not my new field.
Search Results and newly added properties
<ItemTemplate>
<%# ((Examine.SearchResult)Container.DataItem).Fields["nodeName"] %><br/>
<%# ((Examine.SearchResult)Container.DataItem).Fields["summary"]%><br/>
</ItemTemplate>
Cheers, Chris.
Hi Chris
"Touch" your web.config file (ie open it add an extra line somewhere and save the file).
This should get your index "reindexing".
Cheers
Nigel
