  • sun 403 posts 395 karma points
    Dec 01, 2011 @ 09:45
    sun
    I need ghost copy as early as possible.
    When to introduce it?
    Dec 01, 2011 @ 09:48
    Sebastiaan Janssen
    What is a ghost copy and how does it involve Umbraco?
    Dec 01, 2011 @ 09:57
    sun
    all copied nodes are the same physical one. when you update anyone of them, all copied nodes will be updated, because they are the one in fact.
    you can get some information about it.
    http://our.umbraco.org/forum/core/umbraco-5-general-discussion/22905-Umbraco-5-architecture-concerns?p=1
    Dec 01, 2011 @ 10:00
    Sebastiaan Janssen
    Is this for Umbraco 5??
    If it's for Umbraco 4: When you copy a node, use the checkbox that says "Relate copied items to original". Through the Relations API, you can update the related page when the other one is updated.
    Dec 01, 2011 @ 10:05
    sun
    I'm not a developer, I only a normal user. I always think that most user just like me to use most of function.
    But thank you.
    Dec 01, 2011 @ 11:15
    Sebastiaan Janssen
    Sorry, there is no way to do this out of the box, you will need to get a developer involved. :-)
