  • harald 7 posts 27 karma points
    Dec 02, 2011 @ 13:08
    harald
    macro with parameters
    hi,
    i work short time with umbraco.
    I need to work for my umbraco a macro.
    I want to use a macro in Umbraco. It is important that the parameters from the website will be handed over to the macro. How can I write it in the macro so it applies to the handover parameters?
    see here, too:
    code in umbraco
    http://hand4you.com/images/macro_1.png
    code in the macro-programm
    http://hand4you.com/images/macro_2.png
    sorry, my english is not the best.
    harald
  • Barry Fogarty 493 posts 1129 karma points
    Dec 02, 2011 @ 13:29
    Barry Fogarty
    Hi Harald,
    Check out this tutorial video
    Basically you need to create a parameter on your macro (however I would pick a more descriptive name than 'Value')
    Then to hook it up with your usercontrol you create a public property in the codebehind that matches your name of the parameter:
    public string Value {get; set;}
    Dec 02, 2011 @ 14:23
    harald
    hi karma,
    thank you for your rapid answer.
    I was able to fix the problem due to your help!
    Harald
    Dec 02, 2011 @ 14:27
    Barry Fogarty
    No probs.  Speaking of Karma - you can give me some by marking my earlier post as the answer :-)
    Cheers
    Barry
    Dec 02, 2011 @ 16:51
    harald
    hi barry,
    ohh, karma is a  mistake from me, sorry :-)
    Harald
