  • hervey 2 posts 22 karma points
    Dec 02, 2011 @ 19:38
    hervey
    slideshow: how to insert link on a slide
    hello, my question is I am using the slideshow and I am only using images, no text. However, there is no option to setup a link on that image. I guess this should be done in the .xslt file, right? Not sure what code I should enter (rookie here!). Thanks afor your help!
  • Rasmus Berntsen 215 posts 253 karma points c-trib
    Dec 03, 2011 @ 01:51
    Rasmus Berntsen
    Hi Hervey!
    Could you please post the xslt here, then I'm sure that I -or someone else- would be able to guide you in the right direction. :)
    Dec 05, 2011 @ 17:05
    hervey
    Here it is:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
      <xsl:template match="/">
        <xsl:variable name="nodeIds" select="umbraco.library:Split($currentPage/slideshow,',')" />
        <div id="slideshow">
          <ul>
            <xsl:for-each select="$nodeIds/value">
              <li class="rotating-panel fc">
                <xsl:if test="position() > 1">
                  <xsl:attribute name="style">display:none;</xsl:attribute>
                </xsl:if>
                <xsl:variable name="slide" select="umbraco.library:GetXmlNodeById(current()/.)"/>
                <img class="fl" alt="{$slide/@nodeName}" src="{$slide/mainImage}"/>
                <div class="">
                  <xsl:value-of select="$slide/bodyText" disable-output-escaping="yes"/>
              </li>
            </xsl:for-each>
          </ul>
          <ul id="slidePager">
              <li>
                <a href="?position={position()}">
                  <xsl:if test="position() = 1">
                    <xsl:attribute name="class">selected</xsl:attribute>
                  </xsl:if>
                  <xsl:value-of select="position()"/>
                </a>
              </li>
            </xsl:for-each>
          </ul>
      </xsl:template>
    </xsl:stylesheet>
    Many thanks!
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Dec 05, 2011 @ 17:28
    Jeroen Breuer
    If you want to use Razor you can have a look at the Cultiv Razor Examples project. It's a complete website which also contains a slide show.
    Jeroen
