  • gilad 185 posts 425 karma points
    Dec 04, 2011 @ 18:58
    gilad
    Hide second Level Node From Path
    hii everyone.
    i have this structure
    Content
    -- Site
    ---- Home
    ::------ About us
    ::::-------- About 1
    ::::-------- About 2
    ::::-------- About 3
    ::------ Galleries
    ::::-------- Galery1
    ::::-------- Galery2
    ---- Contact us
    ---- News
    any way to "hide" the "Home" folder from the url path?
    i want that this url : domain.com/home/galleries/gallery1
    be this url : domain.com/galleries/gallery1
    for any node under Home directory.
    thanks in advance.
  • Martin Rud 261 posts 1022 karma points c-trib
    Dec 04, 2011 @ 20:54
    Martin Rud
    Try right clicking your "Home" node and choose "Manage hostnames". Add "domain.com" and perhaps www.domain.com.
    Maybe you also need to change <useDomainPrefixes>false</useDomainPrefixes> to <useDomainPrefixes>true</useDomainPrefixes> in /config/umbracoSettings.config. I am not sure, so try adding hostnames alone and if it is not enough then change useDomainPrefixes.
    /Martin
  • Stephen 204 posts 246 karma points
    Dec 05, 2011 @ 12:13
    Stephen
    I have what looks like a similar site to you with multiple galleries, is there a reason for having the additional "Site" folder in your content node? Are you running multiple sites?
    S
    Dec 05, 2011 @ 12:28
    gilad
    hii stephen.
    i need the "Site" folder for the site setting witch i dont want to put it in my home page...
    another reason that is i want to put another folder in the same level of the site..
    lets say - events.
    i have 3 diffrent type of pages that gone use this data..
    Dec 05, 2011 @ 12:42
    Stephen
    Hi Gilad,
    If i have items that i need to store (captured data) i have a settings folder which stores this...so my Tree looks like this..The settings folder will never be seen.
    Content
    -- Home
    -- -- About us
    -- -- Galleries
    -- -- -- Gallery 1
    -- Settings
    -- -- Feedback form data
    You can still have the events folder side by side with the home folder (or under it which would be the way i would do it) and be available on the menu..or am I missing the point?
    S
    Dec 05, 2011 @ 13:24
    gilad
    It makes sense...
    but what about multiple sites?
    in my previous multiple site i made every Main site node Home page.. like that :
    Content
    -- Lang 1 home page
    ---- About
    ---- contact
    -- Lang 2 home page
    ---- About
    ---- contact
    now it is should be :
    -- Lang 1 Site
    ---- Home
    ------ About
    ---- Settings
    Dec 05, 2011 @ 14:03
    Stephen
    I tend not to put multiple sites on the one intall but I agrree this is one scenario where your structure fits...
    Dec 05, 2011 @ 14:28
    gilad
    ok... thank you anyway for  trying.
    cheers.
